Peplink Cellular Modems & Adapters
Peplink cellular modems and adapters add cellular connectivity to existing setups without replacing hardware or rebuilding a network. Used across IoT deployments, fleet operations, remote infrastructure, and facilities running legacy phone systems. Compact, simple to deploy, and managed remotely through InControl.
What are Peplink Cellular Modems & Adapters?
Cellular connectivity for networks, devices, and infrastructure that weren't built with it
Plug-and-Play Cellular
Peplink cellular modems and adapters add cellular connectivity to existing equipment without replacing it. They connect via Ethernet, USB-C, or analog phone line, no complex integration required.
SIM & eSIM Flexibility
Each unit supports physical SIM, eSIM, or both. The 5G Adapter and MAX Adapter include Peplink global eSIM data out of the box, so devices can connect automatically on first power-on.
InControl Management
All models are centrally managed through InControl, Peplink's cloud platform for zero-touch provisioning, remote configuration, and monitoring across 1 unit or an entire distributed fleet.
Learn MoreCellular Modems & Adapters
5G Adapter
Adds 5G connectivity to existing networks and devices. Built for fleet, IoT, and infrastructure deployments, with dual SIM, eSIM, GPS, and ignition sensing included.
MAX Adapter
Adds cellular connectivity for remote monitoring and IoT applications where basic cellular is sufficient. Connects via Ethernet or USB-C, supports physical SIM and eSIM.
POTS Adapter
Moves legacy analog phone lines such as alarms, elevator phones, and intercoms to cellular. Plug-and-play, no additional network equipment required.
5G Dongle
Add high-speed 5G to any router or host device with the 5G Dongle. Industrial-grade, TAA compliant, and features eSIM support for reliable WAN failover.
Ready to Add Cellular to Your Network?
Our certified Peplink partners can help you identify the right adapter for your deployment and support you through evaluation and installation.
