Introduction
Dome Series
MBX Series
PDX Series
Peplink enterprise mobility product lineup including PDX, Dome Pro, and MBX series.
Peplink Enterprise Mobility Routers
Peplink Enterprise Mobility routers deliver fast, reliable cellular connectivity wherever your operations take you, whether it’s on the road, at sea, or in the field. Built to connect across multiple networks and carriers simultaneously, giving your operations consistent, high-speed connectivity across any carrier in your country.
What is a Peplink Enterprise Mobility Router?
Multi-cellular routers for deployments where fixed lines are unavailable or insufficient
Three cellular tower icons representing multi-network wireless connectivity.
Multi-Network Cellular Connectivity
Peplink Enterprise Mobility routers manage 2 or more cellular connections simultaneously across 5G networks, so vehicles, vessels, and field deployments aren't reliant on any single carrier or cell tower.
SpeedFusion icon representing network bonding.
SpeedFusion
Every model includes routing, VPN, firewall, and SpeedFusion in a single unit. When a link degrades or fails, traffic continues over the remaining connections without dropping active sessions.
Learn More
Cloud icon representing network connectivity.
InControl
All models are centrally managed through InControl, Peplink's cloud platform for zero-touch deployment, remote configuration, and monitoring, so IT teams can oversee distributed fleets without being on-site.
Learn More
Dome Series
Outdoor cellular routers with embedded antennas. Designed for vehicle, maritime, and outdoor fixed deployments.
MBX Series
High-throughput multi-cellular routers for vehicles, temporary sites, and mission-critical mobile deployments.
PDX Series
Self-contained, battery-powered router for rapid deployment in remote or field environments.
Ready to Deploy in the Field?
Keep your mobile operations connected wherever they go. Our certified Peplink partners can help you match the right hardware to your deployment and support you from evaluation through to installation.
