Peplink Mobile Routers
Peplink Mobile Routers bring 5G and satellite connectivity to vehicles, retail sites, IoT devices, and remote teams where a fixed line is unavailable or impractical. Built rugged for demanding environments, they're centrally managed through InControl, Peplink's cloud platform for remote configuration, monitoring, and zero-touch deployment.
What is a Peplink Mobile Router?
Compact, rugged cellular routers for connectivity without a fixed line
Cellular Connectivity
Peplink mobile cellular routers use 5G and cellular networks to provide internet connectivity where a wired connection is unavailable, impractical, or needs a backup. They cover use cases from single-modem IoT and retail deployments to dual-cellular professional installations in vehicles and remote sites.
SpeedFusion
Every model supports Hot Failover to keep connections stable when a WAN link degrades. Higher-tier models add SpeedFusion WAN Smoothing and Bandwidth Bonding, so active sessions and critical applications continue without interruption.
Learn MoreInControl
All models are centrally managed through InControl, Peplink's cloud platform for remote configuration, monitoring, and zero-touch deployment across any number of devices without needing on-site access.
Learn MoreBR Series
Compact cellular routers for IoT, retail, fleet, and professional mobile connectivity.
MAX BR1 Mini 5G
A compact 5G router built for mass deployments. Cost-effective, globally compatible, and simple to manage at scale.
MAX BR1 Mini
A rugged cellular router for IoT, retail failover, and vehicle deployments, with remote management and optional connectivity features via PrimeCare.
MAX BR1 Mini Core
A stripped-back industrial cellular router for telemetry and secure IoT applications, with GPIO support and Class I Division 2 certification.
MAX BR1 Mini M2M
A compact cellular router with a built-in serial port, designed to bring connectivity to industrial equipment and IoT devices.
MAX BR1 Pro 5G
A slim, high-throughput 5G router for branch sites and mobile deployments. Works as a standalone router or a 5G adapter for an existing network.
MAX BR1 Pro CAT-20
A high-throughput cellular router for sites that need fast, reliable connectivity with SpeedFusion failover and bonding.
BR Pro Family: BR1 Pro (5GK) & BR2 Pro (5GK)
The latest BR Pro routers with advanced 5G performance, Docker support, and public safety carrier certifications for professional and government deployments.
MAX BR2 Pro
A dual 5G router with multiple WAN options for mobile professionals and vehicle deployments that need resilient, high-throughput connectivity.
MAX BR2
A rugged dual-cellular router for remote and mobile applications that need reliable connectivity across 2 independent cellular links.
BR2 Micro
A compact dual-cellular router for space-constrained vehicle or site installations that still need 2 independent cellular connections.
Transit Series
Cellular routers engineered for transportation and industrial mobile environments.
MAX Transit Duo Pro
A dual-cellular router built for passenger vehicles and transport fleets, delivering reliable in-vehicle connectivity across multiple WAN links.
MAX Transit Pro E
An industrial 5G router for transportation environments that demand wide operating temperature ranges and reliable connectivity on the move.
Ready to Deploy in the Field?
Whether you're connecting a single remote site or deploying across a fleet, our certified Peplink partners can help you select the right hardware and support you from evaluation through to installation.
