Introduction
AP One Series
AP Pro and Rugged Series
Switch Series
Peplink Wi-Fi access point and PoE switch lineup.
Peplink Wi-Fi & PoE Switch
Whether you're covering an office floor, a school campus, a hotel, or an outdoor industrial facility, Peplink has an access point built for that environment. Models range from compact indoor units to IP67-rated access points designed for harsh conditions. Every access point works with Peplink routers and switches and is managed centrally through InControl, so your whole network stays visible from one place.
What is a Peplink Wi-Fi Access Point?
Access points and switches for any environment, managed from one place
Access point icon representing Wi-Fi connectivity.
AP One and AP Pro Series
Peplink access points provide Wi-Fi coverage for offices, schools, hospitality venues, outdoor areas, and industrial sites. Models range from compact indoor ceiling units to sealed outdoor enclosures rated for extreme conditions.
Cloud icon representing network connectivity.
InControl
All Peplink access points are managed through InControl, Peplink's cloud platform for zero-touch provisioning, remote configuration, and monitoring. Push settings to every access point on a site, or across multiple sites, without being on location.
Learn More
Gear icon representing network device management.
Peplink Ecosystem
Peplink access points are designed to work alongside Peplink routers and the Switch Series. VLAN policies, captive portal settings, and network segmentation configured on the router carry through to the wireless layer, keeping the whole network consistent and manageable from a single dashboard.
AP One Series
Indoor access points for offices, schools, hospitality, and general enterprise environments.
Outdoor and industrial access points built for environments where standard indoor units won't hold up.
Switch Series
Managed PoE switches with 2.5G and 10G ports, centrally managed through InControl.
Ready to Build Your Network?
Our certified Peplink partners can help you choose the right access points and switches for your environment and support you from evaluation through to installation.
